Duct Connection
Alwayslearningelec
NJ
Estimator
When you connect bust duct to a breaker in a piece of gear does the copper bus on the bus duct connect to the cooper bus in the gear? No wire connections? Sorry I can't change the title....I see the spelling errors.
I fixed the title for you. Merry Christmas.
The bus connection is often done using flexible bus links rather than rigid bus.
You can connect busway direct to switchboards or switchgear, but often requires a long lead time flange.
We often use a busway cable tap box on the end and transition to conductors for the last few feet from the ceiling down to the SWBD bus.
