The imposed cost didn’t seem to hinder the adoption of AFCI requirements.They are not going to require one because the only two pop-up assemblies listed for use in countertops cost about $200 -$300 dollars.
Every island is going to have something plugged in at some point. An extension cord is certainly more hazardous than an outlet on the side of the cabinet.
I remodeled my kitchen in 2005 and didn't put a receptacle in it. It's never been noticed, never been needed, never been on the wish I would have done that list, and there has never been an extension cord used.Surely many islands will just have no receptacle and cords will be bridging the walkway
Where is it prohibited?..the code simply specifies the permitted locations if you choose to install a receptacle on an island.They were wrong to prohibit one. It's a design issue.
In the 2026 they make it worse with a 210.52(C)(4) locations prohibited.Where is it prohibited?..the code simply specifies the permitted locations if you choose to install a receptacle on an island.
I understand that, but that is simply the inverse of specifying the locations that you can install a receptacle in. There is no requirement to install a receptacle and no prohibition on installing one.In the 2026 they make it worse with a 210.52(C)(4) locations prohibited.
The issue is a receptacle in the side of a cabinet is easier to install and less intrusive than a big pop up in the countertop surface.I understand that, but that is simply the inverse of specifying the locations that you can install a receptacle in. There is no requirement to install a receptacle and no prohibition on installing one.
Not if you read the Consumer Product Safety reports on injuries from adults and children pulling cooking appliances off the countertop because of the cord hanging over the side.IMO the substantiation for this change was weak.
I did read part of it once which is why I said it was is weak. Something like 10k injuries over 30 years. No report on the number of serious injuries and there were no deaths. I've always argued that most of those injuries can be attributed to poor parenting but that's a separate discussion.Not if you read the Consumer Product Safety reports on injuries from adults and children pulling cooking appliances off the countertop because of the cord hanging over the side
And that would look just beautifulEasy solution here is to install cord pendant receptacles, if they are no more than 20 inches above the countertop they are code compliant.
No need to drill through your granite top, probably less cost than listed pop up types as well.
NEC doesn't really care what anything looks like, you just have to sell the idea to your customersAnd that would look just beautiful
My counter top vendor drilled my opening as part out their base cost. My outlet is recessed so it is flush with the counter top until it is popped up. No crumb build up not as ugly as faucets.No need to drill through your granite top, probably less cost than listed pop up types as well.
The next idea would be to install a plug in the pendant light.Easy solution here is to install cord pendant receptacles, if they are no more than 20 inches above the countertop they are code compliant.
Looking forward to reading your Public Input on this issue for the 2029 code...you have until April 9. 2026 to submit it.IMHO the problem of dangling cords getting snagged should have been addressed by a requirement that receptacles on the sides of cabinetry below countertops include some sort of cable management as part of the cabinetry to prevent cords from dangling. If the cords aren't loose and easy to snag as you walk by (or grab as you run by) then the problem goes away.
For example having a tilt out cover over the outlet, where the cover door becomes a shelf that holds the cord up, kinda like this but with the door not sloping down:
Or adding something like a 'fairlead' (used in boating) to guide the cord neatly against the side of the cabinetry up to the top of the counter:
-Jonathan
The issue is that there are some contractors that install to the code minimum so without a requirement unsuspecting buyers may end up with rooms that have no receptacles.I honestly wonder if anyone has ever made a public input to simply delete 210.52. That section dates back before there were widly adopted residential building codes that did address design issues. Its possibly not needed in the NEC anymore and with cordless gizmos being the norm the current minimum standard might be excessive.
