Had a coworker tighten one of these inside a 480 volt 600 amp panel and short out a wire on a 200 amp breaker. For some reason the switchgear 600 amp breaker tripled putting our shop in the dark. I did away with loads of them. Would drill a hole in top dead center of panel cover and use the smallest drill bit that I could still tap a 1/4" 20 hole. Would screw in a grade 5 hex head cap screw with a lock washer with threads facing out. Would use a counter sink to slightly install a taped on heavy 6' panel covers then use a 1/4" wing nut to secure cover then drill and tap 1/4" to secure cover. Would fill up the hole from old dangerous clamp screw with either Allen head button screws or gray caulk.Yes, I'd MUCH rather have the old swing-out wings that clamp to the panel's front lip! Especially on large, commercial panels!
