618electrician
- St. Louis
- Maintenance electrician
If i install 1/2" plywood on the ceiline in my basement can i run romex ( nm) anywher , the plywood would act as a running board ?
Where does the code state that the wires must be run on the side of a joist or running board?the nm cable must be installed on the side of the running boards. not on the face of.
why don't you just bore into the floor joists if they're already exposed?
can some one please explain how to install running boards joist in a basement . pitchers ? this a HYPOTHETICAL question.the nm cable must be installed on the side of the running boards. not on the face of.
You just nail the board to the bottom of the floor joist.can some one please explain how to install running boards joist in a basement . pitchers ? this a HYPOTHETICAL question.
you're right. code only requires it that way within 6' of attic scuttle holes.Where does the code state that the wires must be run on the side of a joist or running board?
How does running them on the sides reduce the exposure to damage versus being on the bottom?...so they say we must do this on the side of running boards...
I thought there was something in 334 that you need running boards for unfinished basements and that that was expanded to crawl spaces.Where does the code state that the wires must be run on the side of a joist or running board?
I agree, except I would use PVC.If you are running NM across the floor joists and don't want to drill them, wouldn't it be easier to just run EMT? and run the NM through it?
You do but you can drill holes instead. It may have been our very own Ryan who made that change. The idea was when is a crawl space a crawl space and not a basement. Rather than define that it was easier to just use running boards.I thought there was something in 334 that you need running boards for unfinished basements and that that was expanded to crawl spaces.
How wide can guard strips be ? ( 4 wires 10 wires 1 wire )
Actually, though holes provides a better support for things like that...on the bottom you only staple every 3rd joist, and you can't hang heavier things on the NMRunning through bored holes does not prevent them from being used clothes rods or to support skis, canoe paddles, fishing rods, and other long objects.
They just have to be higher than the cable they protectHow wide can guard strips be ? ( 4 wires 10 wires 1 wire )
