jaggedben
- Northern California
- Solar and Energy Storage Installer
As I said at the beginning, there are many thousands of homes where a Tesla EV is coexisting peacefully with Eaton AFCI breakers. And so especially if the breakers are replaced with new ones, that means it's likely something with the car that is making the difference.I'm reluctant to blame the breakers because the breakers all function properly until the Tesla charging is introduced. I believe there is something in the relationship between the Tesla charging and the afci, GFCI, and GFCI breakers that is causing a problem. And if Eaton is not aware of it, they should be. If Eaton was aware of it, the consumers should have also been aware of it. I sincerely appreciate all the feedback and attention this has gotten. Hopefully at the very least it will help someone else in the future
Look, there's a difference between narrowing down "what's going on" and providing a practical solution. As far as solutions...
The AFCI detractors on this thread are surely correct that if you replaced the AFCIs with regular breakers, you'd have no more issues. Upside: easist and cheapest. Downside: you're out of code compliance, liability, blah blah blah.
You can replace the whole Eaton panel with a different brand with different AFCIs. Upside: likely to solve issue, 100% code compliant. Downside: more expensive, small chance you still have issue.
I've suggested repeatedly to test with a different car. If the problem only occurs with a particular car, then asking Tesla to look at the car, which is under warranty, makes sense. Upside: might solve the issue cheaply without being out of code compliance. *Necessary if your interest is to understand "what's going on".* Downside: whoever you get at Tesla might not be competent or diligent enough to find it, might shift blame, might be a big waste of time. Owner probably doesn't want to replace car (but maybe they do?
There's a possibility the EVSE is to blame. You could replace it. Upside: not as expensive as replacing the Eaton panel, let alone the car. Downside: arguably least likely to fix problem, pontential waste of time and money.
