how does this work?See
Burndy ZM
ZM615, Copper - Multiple Outlet Connector (Mole) | ZM615 | Burndy
Copper Alloy Pre Insulated Junction, 25.12 in L, Number of Outlets: 6, Ampere: 1500www.hubbell.com
This connector is designed for underground networked installations. The one I showed or the Polaris type would be better for what you want to do, if I understand correctly.how does this work?
Will those splicer connectors be placed inside a pull box?This connector is designed for underground networked installations. The one I showed or the Polaris type would be better for what you want to do, if I understand correctly.
Mark
The type in post #3 usually go in a vault underground. The types in posts #2 and #4 are more likely what you're looking for and yes those go inside of a pull box. If you have access to a crimper you could use a barrel type connector.Will those splicer connectors be placed inside a pull box?
These would generally be in a manhole or junction box.Will those splicer connectors be placed inside a pull box?
