How many feet are in a ton ?About to install a ton of 2.5”-3.5” emt. Set screw couplings. What’s the best way to get a string through them when finished.
20,000’How many feet are in a ton ?
Mouse and a vac.
Can you tape the couplings?Longest run is 450’
A couple strategically place C condolets might help.Longest run is 450’
That’s why I want to come up with a game plan before we run the conduits. You can spend a lifetime getting a string through a conduit in a bad scenario.A couple strategically place C condolets might help.
Big fiberglass fish tape utility guys use on underground. On a 4’ tall reel. Usually 7/16” diameter. Won’t go through anything less than 3”.What is duct rod?
I would blow a plastic grocery bag through with a string tied to it.About to install a ton of 2.5”-3.5” emt. Set screw couplings. What’s the best way to get a string through them when finished.
1000 kg / 12kg =83.333 (10 ft) lengths of 3” EMTHow many feet are in a ton ?
Mouse and a vac.
Leaf blowers typically will push them better than exhaust port on many shop vac's will.I would blow a plastic grocery bag through with a string tied to it.
It works great for me every time.
