Hello everyone I run into this situation
Customer call because the light in the dining room is flickering when a light in the guest bathroom is turned on. In both locations there’s a dimmer switch.
I installed a regular switch in the bathroom since not need a dimmer and I installed a new dimmer switch in the dining area.
The dimmer is LED, incandescent and halogen compatible but the problem persists I’ll check the wiring and everything looks good.
Have you ever run into something similar?
