Light flickering
Erod10
Virginia
Hello everyone I run into this situation
Customer call because the light in the dining room is flickering when a light in the guest bathroom is turned on. In both locations there’s a dimmer switch.
I installed a regular switch in the bathroom since not need a dimmer and I installed a new dimmer switch in the dining area.
The dimmer is LED, incandescent and halogen compatible but the problem persists I’ll check the wiring and everything looks good.
Have you ever run into something similar?
90% of the issues I find are cheap Chinese bulbs-
If the thing pulsates with a rhythmic beat you have your answer
Yep. The LED is failing; replace it. Be careful; sometimes when they fail that way the bases get very hot.
