EGC twist .
St. Louis
Maintenance electrician
Cain i twist solid EGC totether for a splice. ( on wire nut ) ?????????????????????????????????????????????????????????????????????????????????????????????????????????????????
250.148 references 250.8 and 110.14(B) as requirements for splicing. These would prohibit ONLY twisting for the wire as a means of splicing and would require a splicing device or by brazing, welding, or solder but if soldering the connection must be mechanically secured before soldering.
