Can a die cast zinc offset be used with a RMC service riser?
It would be placed coming out of the meter socket. I need to get about 1 1/2” away from the siding due to a step in the surface finish of the wall.
Due to the way the existing mast is going through the soffit and roof assembly it would be a lot of work to change the entire pipe to bring it out that distance.
I’m not sure if the thread type would allow for being able to screw it into a 2” Rigid coupling.
I’ve just always known them as offset nipples and used them between enclosures for instance.
