zemingduan
- Philadelphia,PA
- Electrical Designer
It is a 4-story multi-family building with solar panels and inverters on the roof. The PV system A/C disconnect will be located on the exterior wall next to the building electrical service equipment/disconnect and utility meters. After the PV A/C disconnect, the A/C wiring will run inside the building to the indoor house panel and interconnect with the system at the house panel.
My question is that, does NEC requires the A/C wiring between the inverter to the PV system A/C disconnect to run outside the building? Can you run it inside? If yes, do you need additional disconnect at the entrance point?
Thanks!
Thanks!
