Dale001289
- Georgia
The code doesn't say 'same materials'. It also doesn't say 'same capability'. It says 'same characteristics'.
The conventional interpretation of 'same characteristics' is same material, same insulation, same conductor arrangement, same type of conduit, etc.
This is based on having current divide evenly between the paralleled conductors. Small differences in impedance between the two conductors will result in uneven current sharing.
If you picked two random conductors, both of 150A ampacity (say 1/0 Cu with a 75C rating of 150A in a steel conduit and a 1/0 Cu with a 75C rating as part of an Aluminum MC cable, and put them in parallel, then they would have _different_ characteristics and you would expect uneven current sharing.
-Jon
Slightly irregular impedance that “might” result in a couple amps differential isn’t enough to worry about. I’ve never seen parallel conductors carry the exact same current or voltage.
