boboelectric
- Eighty Four,Pa.15330
Check out Arlington One box
JohnConnolly said:Can you quote the violation in chapter 3 regarding using screws to attach a plastic box to a stud?
I did have one inspector YEARS ago who complained. His issue was that the screws were not grounded so I satisfied him by putting a dab of caulk over them.
If I were an anal retentive inspector I could shut down almost any project with code interpetations.
Here is one of my !6' box trucks.
314.23(1) Nails and Screws. Nails and screws, where used as a fastening means, shall be attached by using brackets on the outside of the enclosure, or they shall pass through the interior within 6 mm (1/4 in.) of the back or ends of the enclosure.
bjp_ne_elec said:Sitckboy - you have a hyperlink in one of your posts, but it's the home page for Pass & Seymour. What model number box did you have in mind?
THanks
Just because an inspector says it is okay does not necessarily mean it is a code compliant installation.
