PVfarmer
- Newport County, Rhode Island, USA
a residential ground mount with inverter at the array should be permitted to run at 1000V.
The issue of the 600V rating on the Fronius Primo data sheet may still be a problem that needs to be solved, though.
To me the "on or in other buildings" part sounds like 1000VDC panels on a garage roof to a 240V inverter inside the garage are ok.
I read 2017 as-
If the 240VAC inverter is attached to a house with 1000VDC wires attached to it, that is not allowed.
If the inverter is not attached to the house, then 240VAC is the voltage that is "on or in" the house.
Max. input voltage
600 / 1000V**
**The maximum voltage for installations in or on residential dwellings must not exceed 600 Vdc.
http://hespv.ca/hesproductspecs/Fronius/Fronius_Primo_compressed.pdf
