hurk27
- Portage, Indiana NEC: 2008
Rotating the pole is not a problem if you have two pieces of heavy equipment and a crane cable to wrap around the pole, even two 5 ton come along can do it ( not the first time I have had to relocate the bolt through hole after realizing it was in the wrong direction)
But moving the service around the pole can be done fairly easily if your good at rigging a jib at the top of the pole to take the weight of service and swing it around to the other side, you might check around and see if someone has a pole jib in your area, all it is is a boom that has a pulley at the top and you lag it to the side of the pole half way between the existing point and the new placement using a secured wench to take the weight off the mounting.
