ptonsparky
Tom
- EC - retired
Kinda what I was thinking.Do you have a voltmeter? It will answer your question.
Noooooo, do not mention 2 phase. That is a whole different system here.
This is called single phase derived from 2 poles of a three phase system.
Why?
It just is, trust me. Confusing but true.
2 phase can be 3, 4 or 5 wires. Still two separate single phases 90 degrees out of phase from one another, but 3 and 5 wire versions have a "common" that ties each coil together. 3 wire common is at one end of each coil, 5 wire midpoint of each coil is tied together.The way I explain it is "how many different ways can you get pole-to-pole?
Single phase therefore requires two of the poles.
Three-phase requires all three.
I did research the old "two-phase" systems. They used 4 conductors and were basically two separate single phase circuits created out of phase with each other if I'm describing that in a way that didn't make things worse.
Might have been better to have left 1PH off the label.
The Le Blanc connection exists to get two phase.I've decided that 2 phase does not truly exist.
No, that is the correct designation. I know you don't like it. How about go for a walk with that handsome dog of yours and forget all about it![]()
It isn't about liking it or not liking it. One voltage is line to line, the other line to neutral. The two voltages are not in phase. But, call it 1PH if you wish.
And, yes I did walk the dog.......![]()
Not sure what point you are making WRT to line to line and line to neutral voltages?There is a difference between phase shift and phase inversion.
That they are not "out of phase" on a single-phase service.
Did the UK never have 2-phase? It was pretty popular at one time over here. I forget how that came to be exactly but I would think y'all would have had a similar development.
I have yet to see a real two phase system myself - and probably won't unless I go east.I've decided that 2 phase does not truly exist.
Y'all made it up just to drive me bonkers.
Not very nice IMO.
Chapter 8 of the J&P goes into the Scott and Le Blanc connections in some detail.A bit late. We did and still do use 2Ph.
Different topic. A 180 shift doesn't apply.This comes up a lot in audio; many folks call the complementary lines of a balanced circuit "180 degrees out of phase" but if that's what it was the shift in time for every frequency would have to be different. In "pure" 60Hz the difference isn't as significant, although for L1 and L2 to be 180 out a spike on one line would not be seen on the other until 1/120 sec later. Inversion is not the same as phase shift.
I feel your pain........Oh, dear Lord....not again.
