MAC702
- Clark County, NV
Does this help, or make it worse?
The windings look like they are reversed.
Ha, I didn't look at that part! Just grabbed the pic off the 'net when I saw the waveforms.
Here's one that ignores the xformer guts. Is this better?
It is a step-up transformerThe windings look like they are reversed.
Don't know that I agree with what is on that graph.Ha, I didn't look at that part! Just grabbed the pic off the 'net when I saw the waveforms.
Here's one that ignores the xformer guts. Is this better? Except I prefer the terms Line 1 and Line 2 (or Pole), as the Phase is better described as the path between poles. That's why this is a "single phase."
It's nonsense. And irrelevant to the point made by the OP.Is this better?
The volts scale should be from -120 at the bottom to +120 at the top. When one line is +120 it is 120 volts to zero crossing which is where neutral is at and 240 volts to the opposite line
But it is actually more complex then that as what we typically measure 120/240 is actually RMS voltage, the actual peaks would be about 170 volts each side of zero crossing.
Black is line to line. Red & blue are each line to neutral. I'm ok with that.
I totally agree with your comment about RMS vs peak, however.
Different topic. A 180 shift doesn't apply.
Feel free to disagree - it is a discussion forum after all.I disagree, but we'll just leave it at that if it's OK with you.
Just let's be amicable about it.
I thought we both were. Absolutely nothing to apologise for.I thought I was.
ggunn said:...apologize
...apologise...
...But it is actually more complex then that as what we typically measure 120/240 is actually RMS voltage, the actual peaks would be about 170 volts each side of zero crossing.
The traditional 2 phase is a subset of a symmetrical 4 phase system. And some systems labeled 2 phase are more correctly called a 4 phase system. Straight out of engineering reference texts.2 phase can be 3, 4 or 5 wires. Still two separate single phases 90 degrees out of phase from one another, but 3 and 5 wire versions have a "common" that ties each coil together. 3 wire common is at one end of each coil, 5 wire midpoint of each coil is tied together.
So there it is. Labels are not always completely descriptive of a system's physical characteristics. If one tries to make the label match the physical we would need more complex system names and that is really not going to happen.It isn't about liking it or not liking it. One voltage is line to line, the other line to neutral. The two voltages are not in phase. But, call it 1PH if you wish.
And, yes I did walk the dog.......![]()
The label is just a label. It does not change the physics of what is present.That they are not "out of phase" on a single-phase service.
Quite. This thread is about a 120 degree shift.Different topic. A 180 shift doesn't apply.
