speedypetey said:
wbalsam1, I certainly hope you do not work for the NYBFU.
Been there, done that. Got a Tee shirt. Senior Inspector. Worked there 9 years. Got all the way up to a heaping $23,000 and a car. More than 1 bird in the nest to feed so I had to move on.
Great job for a retired person. :smile:
speedypetey said:
The practice you describe sounds fine...as a suggestion. You following company rules is one thing.
I'm required to follow company rules as a term of employment. Not only inspection agencies develop policies, but pocos, too. Can you think of poco policies you have to follow in order to get a service energized? I can. Policies cover subjects of mutual interest to the parties involved. An underwriter has an interest in cooperating with the parties just like the poco does. A poco not only requires compliance with codes but also with it's specifications. They reserve the right to deny service, just as an underwriter reserves the right to nullify an inspection contract if it's policies are not adhered to.
speedypetey said:
You TRYING to enforce a made up code is another thing entirely.
What if I don't comply? Do you fail the whole job? On WHAT grounds? You have NO written code to enforce other than the whim of the owner. It's not like there is even a vague code that could be misinterpreted to require this.
1st of all, I'm not trying to enforce a made up code. It's not a code, it is a term of an agreement between two contracting parties. It's a company policy. The question
"If you don't comply" doesn't apply since it's the inspector that tags the circuit. You do not have to do a thing. You actually do comply with the code and you're not being cited. Why would I fail the whole job? :-? This is an unrealistic, alarmist-type question. To your statement that I have NO code to enforce....I'm not enforcing code, but rather a policy. When a power company tells you "no grounding electrode conductor in their meter", do you disobey them because it's not in the NEC? Of course not. You have come to realize that there are rules as well as regulations.
speedypetey said:
Again, I don't disagree that a tag stating that there is a smaller wire as part of the circuit is a bad idea. It's just making up a rule that your clients are supposed to follow is NOT a good thing.
Here we disagree. Read insurance policies, power company schedules and spec books, and note that companies all over the place reserve the right to challenge the work when rules and regs are suspect.
speedypetey said:
If I were put in this situation I would have to wonder what other things this guy was making up that I would need to comply with to get a green tag.
Here you really mean 'what other policies does this inspection agency have'?
speedypetey said:
I would also look to one of the other several approved third party inspection angencies in my area.
You certainly reserve the right to choose your inspection agency from those that have been approved in your community. I personally like the extra touch of someone looking out for the installation long after their client has gone. If something goes wrong, usually attorneys like to invite not only the inspector to the accident scene, but also the installer. This is a case where a written record (stored in a safe place) of such a document could come in handy.
