Craigv
- Boyertown, PA, USA
Actually yes. I can't speak to that particular unit, but others can be split to be fed by two circuits. Pass & Seymour 420-HI for example.I don't see how the individual receptacles can be separated from the assembly, and would think that means they are on the same yoke/strap.
Is this device assembled in such a way that the individual outlets can be on different circuits? From my interpretation of "2 poles, 3 wires" at this description, I'm thinking no.
https://www.zoro.com/hubbell-wiring...uad-20a-5-20r-125v-ivory-hbl420hi/i/G0594167/
https://www.gordonelectricsupply.co...h~product~part~5629846~ds~dept~process~search
At issue is: what is a "yoke or mounting strap"? NEC doesn't define it (natch). I take a rather literal view ad NEC seems to be literal in the things it does define. These quads have no yoke that I have seen, nor a mounting strap. They are plastic composite molded faces with mounting holes.
Larry Fine mentioned that we may see a code change regarding this so I'm guessing these have been interpreted as not being subject to 210.7.:?
