Fulthrotl
~Autocorrect is My Worst Enema.~
- E
I bought a house with a 15 year old Generac Guardian 4079-1 10kW standby generator that the owner builder never finished installing. It's never been used. The transfer switch is running to one of my 100A subpanels so that's wired. The lp line is all set to go.
Does anyone have any experience or knowledge if it would be a good or bad idea to try and get this working? It goes against my better judgement and I'm leaning toward just ripping it out and installing a new Briggs & Stratton 10kW standby. I don't want to risk dirty power blowing stuff up if I get it fired up.
Any experience or wisdom would be greatly appreciated.
there's a number of things you can put in to lube the cylinders, before spinning it up.
if it was mine, i'd put a squirt of aero kroil into each spark plug hole, and see if it turns
thru a couple turns.
then drain the existing oil, and refill.
put the plugs back in it, stick a fresh battery in it, and start it up.
first running, let it go at a fast idle for about 20 minutes, and shut it down.
drain the oil and refill.
now, treat it like a brand new unit, change the break in oil when suggested,
and i'm betting it'll run a fairly long service life.
