- Massachusetts
480 just didn a pretty good job of it himself right above your post.
That was no voltage drop calculation.
agreed....Without double-checking Ed's numbers, I think that's already been done.
the diagram pretty much shows it, at least to me it does, that the mere fact of not having the extra neutral in there reduces not only the voltage drop but also the load on the neutral.That was no voltage drop calculation.
We still disagree and this is my plane.
true, length is not the story load is but also the number of neutrals is the story just as well.I don't think length is the story, load is. Look at the load on the neutral in Ed's diagrams.
That's funny. SR71s what what for armaments?
I never said I was shooting anything, that was your game.
I am just flying at the edge of space at Mach 3.
Anytime you use a multiwire branch circuit you can reduce voltage drop. (Assuming same loads, same size condutors, same length etc.)
From a long ago thread
space has no edge.
space has no edge.
NASA is going to be upset to learn that.
Strange Clouds at the Edge of Space
AIM at the Edge of Space
It will work on 3-phase too, just not to the same degree because the currents are 120 degrees out vs 180 of single phase.Ok this is something new to me. I now can understand this concept, however, what dereckbc said makes it sound like you will only reduce the voltage drop if you use the shared neutral on single phase. I don't see how this would make any difference. Another words this concept should also work on 3 phase just the same.
they know nothing!NASA is going to be upset to learn that.
Ok look, Who has a need to install a service at the edge of the universe? And if so, does the NEC have jurisdiction?
The NEC has no jurisdition anywhere. That's the AHJ.
