I need to step up the voltage from 208 to 480V transformer for an AC load of about 350KVA. I am assuming I will have to go with a Y to Delta transformer.
The problem is the safety ground at the equpment if I go with a Y to delta transformer. The question....Can I get Y to Y step up transformer so I could ground the equipment thru the Y center tap of the ransformer? Any suggestion on past experience from someone who has gone thru similar jobs?
Thanks,
Thanks,
