Maybe someone can post an example of a panel schedule.
Okie-dokie!Maybe someone can post an example of a panel schedule.
Still tarp as a shack. :grin:Okie-dokie!
08:00 - 08:30 .......... Install panel
08:30 - 08:45 .......... Remove KO's, install cable clamps
08:45 - 09:00 .......... Insert cables in clamps
09:00 - 09:30 .......... Make up EGC's
09:30 - 10:00 .......... Make up grounded conductors
10:00 - 10:30 .......... Morning break time
10:30 - 10:45 .......... Install breakers
10:45 - 11:15 .......... Make up ungrounded conductors
11:15 - 11:30 .......... Install panel front cover
11:30 - 12:00 .......... Make up panel label
12:00 - 12:30 .......... Lunch time
How's that? All done by lunch!
Yank thou!Still tarp as a shack. :grin:
Nice panel schedule.Please see the attached file.
However, it appears to have an excessive number of conduits used. 29, 20mm? (3/4") conduits outgoing for 2-wire w/ground circuits (assuming ckt#16 is a typo). Is there a means to combine into lesser number of conduits, or is this how it is spec'd by the USACE? Or does one simply ignore the implication and refer to an electrical floor plan?
oh, good point. But in design we have to show condiut for each branch in interior design. But in implementation
If the two, three or four branch come in the same path. We use NEC chapter 9 number of wire per condiut. The maximum size for interior distribution we can use is 2 inch and it has capacity of 28 or 30 wire or so.
In this way, number of condiut can be reduced.
That being the case, I believe there should be a "footnote" to that effect on the schedule.
