Volta
- Columbus, Ohio
So now we're left to define how far in front of the wall can still be considered wall space.
Other than 18"?
Other than 18"?
"...no point measured horizontally along the floor line in any wall space is more than...
Given the fact that the description of "wall space" as used in that Section disallows traversing a doorway, fireplace, or similar opening, I don't see how a separate wall space can be considered as a possible interpretation.
You don't measure a "point," horizontally or otherwise. The "measured horizontally" has to be referring to something, but it is not (as would be required by common rules of English grammar) referring to the word or phrase immediately preceding it. That is part of the reason that I submitted a proposal to change the wording of this article. It is simply bad grammar."...no point measured horizontally along the floor line in any wall space is more than..."
That interpretation allows the 6 feet to be measured across a doorway. I don't like that fact, and that is why I still think this article needs to be reworded.. . . no point in any wall space is more than 6 feet, measured horizontally along the floor line, from . . . .
I disagree that it is a fact, it is your opinion.![]()
I do not think you will see it changed as IMO it says what it means as it is. I am willing to bet the CMP sees it the same as well.
Walls space, as defined in this article as being UNBROKEN BY DOORS,,,,,,
I don't see anything confusing about it
Wall Space. As used in this section, a wall space shall include the following:
(1) Any space 600 mm (2 ft) or more in width (including space measured around corners) and unbroken along the floor line by doorways, fireplaces, and similar openings
(1) Spacing. Receptacles shall be installed such that no point measured horizontally along the floor line in any wall space is more than 1.8 m (6 ft) from a receptacle outlet.
(1) Spacing. Receptacles shall be installed such that no point measured horizontally along the floor line in any space 600 mm (2 ft) or more in width (including space measured around corners) and unbroken along the floor line by doorways, fireplaces, and similar openings is more than 1.8 m (6 ft) from a receptacle outlet.
Now let's look at spacing
Now let's do simple algebra---substitution we'll remove the words "wall space" and put in the definition.
Does that change anything?????
As I see it, the problem with current wording is it only requires the point measured from to be in any wall space. The wording does not specifically require the receptacle to be in the same wall space as the point measured from.In the real world it is understood to mean what we have all been doing. Personally, I think it is quite clear.
Wall space is defined as -- we will just look at #1
I think Charlie agrees with this.
(1) Spacing. Receptacles shall be installed in each wall space such that no point measured horizontally along the floor line of the wall space is more than 1.8 m (6 ft) from a receptacle outlet.
That is exactly how I see it.As I see it, the problem with current wording is it only requires the point measured from to be in any wall space. The wording does not specifically require the receptacle to be in the same wall space as the point measured from.
This thread has stupid writtin all over it. This is the very first thing you learn in residential layout. I believe it reads the same now as it did 40 years ago when my brain had 18 years of dumb on it. A door stops wall space and begins a new wall on the other side. If there is a 2' wall than another closet door that 2' wall gets an outlet. I always placed an outlet behind the inswing bedroom door to allow for an open wall space outlet for the vaccume cleaner. The ladies loved that. Never pushed the 12' thing. Always had at least one outlet on every wall. Jim Walters made some pretty small houses back in the day.
I NEVER thought it to mean differently, what the others are saying bears true. I had to think it over several different times to get what they meant..
