mivey
Maybe we digress. There is no new label over an old label.So with your new correction (edit) made, I will return to the response that I was already anticipating that I would need to make. What you have in effect done is placed a new label over the top of the original label and reversed the dot-convention at the same time. If we peel back your label, we will see the original label and dot-convention. It didn't change the original power supply, it only gave it a new label that may lead to confusion (yes, I was planning on pointing out "lead to confusion" before you made your faux paus. That is why I was happy to see your faux paus.).
I'm saying that the Vs and Vx are my two generator units from post #98. The labels did not change. The wiring did not change. The connections did not change. The load did not change. The only change was a 180? rotation of one winding relative to the other. All of the wiring, polarity marks, labels, etc are the same on both units.
Your two Vs outputs are two of my units but with no rotation difference in the windings. In the two Vs case, one of the generator units would have to be re-wired and re-labeled or the two voltages could not combine to make a double magnitude voltage at the generator output. They would just be two voltages in parallel: smaller voltage but twice the current capacity.
My Vs and Vx outputs are two of my units with a 180? rotation difference in the windings. In the Vs and Vx case, no re-wiring or re-labeling needed and the voltages would combine to make a double magnitude voltage at the generator output. Twice the voltage but 1/2 the current capacity of the paralleled outputs.
