OkayTry GEMI and see how it works
In a perfect world yes. In my scenario it’s not a GFPE.If it’s 15 through 50 amp lighting circuit I'd just use a GFPE breaker and a regular sized EGC, if more than 30ma needs to flow on the equipment ground continuously I'd want to know why.
It doesn’t work on iPhoneTry GEMI and see how it works
My thoughts: One luminaire failure potentially takes out the whole circuit instead of a supplementary in line fuse isolating the problem area. And probably trips it before the fuse blows so when you try to reset it shuts down the whole circuit again.If its 15 through 50 amp lighting circuit I'd just use a GFPE breaker and a regular sized EGC, if more than 30ma needs to flow on the equipment ground continuously I'd want to know why.
