As the title states. Yeterday I recieved a 277V shock. I was working above a drop ceiling on an 8' ladder. I was in a j box and simply tracing wires to eliminate a motion sensor after a room was extended. I had my right hand on a 3/4" Emt(yeah I know) and with my left hand I was holding a wire nut and pushing it out of the way so I could see where a wire was going behind it. I believe that as I moved this wire nut the power line came free from the nut and hit my hand.
I was locked in and I knew it. In I believe what was only 1 second this happened... First I said out loud ,"Oh God" as I tried to pull away. Not being able to pull away a pushed as hard as I could with my legs against the ladder. The ladder folded and I believe I fell flat on my back.
As I sat on the floor I knew I pretty much shouldn't be alive considering I got locked in and was by myself. I did not expect to be able to talk, think, or by any means move my legs enough to push the ladder while locked in. This still amazes me today.
I did go to the ER after about 20 min. and they kept me there for 6 hrs. Two urine tests and two Ekg's later they said we see no heart damage consider yourself very lucky and you can go home! They did tell me to keep antibiotic on my hand cuts as I had no burn marks at all they assume there is damage under surface and I should watch for infection. Today I wake up and am very sore from the fall and sholders both hurt but I feel pretty Blessed.
I guess I just felt the need to share this tale. Also was curious if anyone had similar experience, and if I should still go back to my regular doctor just to be safe, and would would I have them look for if anything.
