220/221 said:Do condulets require support?
iwire said:Not that I am aware of. Normally they are supported by the raceways, take away one or two of the raceways and it is not really supported as well.
So what I am trying to say is I just don't know if what your suggestion is a violation or not.
For wall packs I do. For switches on large commercial jobs I mount a 1900 with X-ring and stub up a 1/2" EMT with 90 at deck level. This allows me to get a wall rough(hang the rock) but gives me flexability with the lighting. Do it all the time with connector, coupling, and connector.cowboyjwc said:It sounds to me like this is for some wall packs or something similar?
Why didn't you just run the whips through the wall?
iwire said:For us often it is fire alarm device stubs in 3/4" EMT.
The rock will be going up before the fire alarm system specifications are finalized.
chris kennedy said:Those we just tap an EMT 75 on the end and were done. No change over required.
iwire said:You are right, there are many ways to get it done, I will sometimes use a box.
The advantage to fittings is they do not need supporting.
We need to see the listing for a ridgid coupling.(little help please Marc)Jim W in Tampa said:I am now not sure if its legal.Can we fit an emt connector to a rigid coupling ?
chris kennedy said:We need to see the listing for a ridgid coupling.(little help please Marc)
Jim, how often have you seen RMC come out of a slab and change to EMT before it hits a gutter or panel?
Jim W in Tampa said:Often but now not sure if its legal.Just did a lot of pvc in slab and changed it to emt with female adapter (pvc).Never had an inspector say anything about changeovers other than i cant conceal them.
Jim W in Tampa said:Never had an inspector say anything about changeovers other than i cant conceal them.
EBFD6 said:are you saying that concealing a conduit changeover is illegal? We often run PVC underground and then change over to RMC sweep and RMC up pole, changeover gets buried, never had an inspector make so much as a comment
Jim W in Tampa said:He would not let me change from emt to mc inside wall.
EBFD6 said:I don't understand the problem, just a changeover, no splices or anything, I don't see any issues, but thats JMSO :grin:
Doing something and passing does not make it legal.
