Jerseydaze
I have an existing building that is block with 3/4 fur strip .I plan to run RX but I am having a hard time finding a box that will accommodate switches and receptacles that is 1 1/4 deep nail on Anyone have suggestions?
Just curious, do you nail the NM cable to the side of the fir strip ? How do you hold the JB in place ? Metal or plastic ?Yeah. get a big hammer and a demo hammer, blow out the block as needed.
We run into this a lot in apartments and assisted living buildings.
Ever have an endless flow of vermiculite come pouring out?Yeah. get a big hammer and a demo hammer, blow out the block as needed.....
For us it usually MC cable and metal boxes.
Some sort of screw on cable support will be used to secure to the metal 'high hat' (strapping)
Caddy makes a strap call CJ that holds mc inch and a quarter away from the strip.
IMO furring strips is a lousy way to build out block walls if you want boxes behind the drywall.
Not since I tried to cut in a box on an outside wall of a two story block wall. Yeah ... a big pile. :rant:
Yeah Caddy CJ-6 we use them but they are pretty weak at keeping the cables under control.
I am impressed, you waited 9 posts to say that.![]()
I am having difficulty finding a link but there is a plastic box that has a "side compartment" giving it more cu in that I recall is for use on furring strips
That's great but it's a remodel box and it won't fit in a 3/4" firred wall.
Never seen one that fits in 3/4 inch space.I am having difficulty finding a link but there is a plastic box that has a "side compartment" giving it more cu in that I recall is for use on furring strips
Unless you only have one or two boxes to set in such a wall - tell the owner, builder or whoever that it will cost them less to just use 1.5" fur strips then your labor will be to carve out all the masonry for you to get your stuff in there.
I think it goes beyond making an EC's life easier. I think it's a case of going cheap and dirty up front and then trying to do the same on the tail end. We're talking about another 3/4" all the way around the room. I can understand not wanting to pay a carpenter to rip out the fir strip and install std. studding. What I have trouble with is that they are willing to pay an EC to bust out the block rather than pay a carpenter to install another layer of strip on top of the existing.No, that will not fly, not in the places we do. They are not going to loose space permanently just to make the electricians life easier.
