- Massachusetts
I find things get done much faster if I just do it and stop talking about it. But that's just me.
:thumbsup:
Welcome to the forum.
I disagree, please post the code section to support that.
The cables can touch the drywall as long as they are 1.25" away from the edge of the framing member
Ever use them?They manufacture staples for masonry
http://www.westwayelectricsupply.co...Nj-atHWaNd6gRPokATPHpCGzsaQs2fQiycaAq6c8P8HAQ
I'm thinking you can put as many screws as you want, whatever length you have in a stud, six inches long half inch apart if you desire, and if the wire is an inch and a quarter away from that stud it will never get hit.....Ok, I suppose that you could interpret that to mean either horizontal distance away from the stud or depth in from the edge of the stud. I've always taken it to mean depth because the intent is to prevent long screws or nails from piercing the cable.
-Hal
You ever been on a renovation where one side of wall was completely opened and when looking at what is there you notice all those screws in the other side that never hit a stud and wonder what is holding the drywall in place other then maybe the construction adhesive they used and a few screws at the ends or just the "starter screws" for that panel?I'm thinking you can put as many screws as you want, whatever length you have in a stud, six inches long half inch apart if you desire, and if the wire is an inch and a quarter away from that stud it will never get hit.
You ever been on a renovation where one side of wall was completely opened and when looking at what is there you notice all those screws in the other side that never hit a stud and wonder what is holding the drywall in place other then maybe the construction adhesive they used and a few screws at the ends or just the "starter screws" for that panel?![]()
You have a point in that if Ol' Dead-Eye is 1-1/4 off he probably has a bad nickname.Normally drywall screws are chosen to penetrate the stud 1/2 to 3/4 inch. This is why bored holes have to be 1-1/4" in from the edge of the stud. But if someone is stupid enough to use six inch screws nothing is going to help.
Never underestimate the ability of Ol' Dead-Eye the rocker. At least he's using the correct length screw but 1-1/4" horizontally isn't much. If there is cable 1-1/4" away and within 1/2 inch of the back of the sheetrock it can get hit. If it's 1-1/4" in there is no chance. This is why those Caddy CJ6s and other stackers maintain 1-1/4" in both directions.
Matter of fact wouldn't you have to straighten the CJ6s to remove the 1-1/4" offset to use them in a 1X furred wall? Isn't that modifying a listed product that would void the UL listing?
-Hal
You can use it for side wiring a very shallow receptacle.So I went with blowing big holes in the block and using 18 cu in plastic boxes .It was pretty easy using my rotary hammer with a chisel bit.
On a side not what can you use this box for ?
http://www.homedepot.com/p/1-Gang-8-cu-in-Flanged-Shallow-Old-Work-Box-B108R-UPC/100404058[/U]
I am having difficulty finding a link but there is a plastic box that has a "side compartment" giving it more cu in that I recall is for use on furring strips
This shallow old workbox 17 cu.in.
http://www.homedepot.com/p/1-Gang-17-cu-in-Shallow-Old-Work-Box-B117RSWR/202077341
Living in an older mobile home, I have these in all the interior walls as a standard box just won't fit![]()
