Use it with a fixture that has a canopy that is marked with the volume.
(Easy to say, not so sure it is easy to find)
Pan boxes have there place, also as far as box fill goes if a light fixture has a domed canopy that volume can be added to your box fill volume. Read it someplace.
If it marked with the volume as Iwire stated above.
314.16(A)
(A) Box Volume Calculations. The volume of a wiring
enclosure (box) shall be the total volume of the assembled
sections and, where used, the space provided by plaster
rings, domed covers, extension rings, and so forth, that are
marked with their volume or are made from boxes the dimensions
of which are listed in Table 314.16(A).
So many things go in and as time goes by just as many go out.
Note, it does not say Factory Marked or Manufacturer Marked, just marked.If it marked with the volume as Iwire stated above.
314.16(A)
I don't see why not.So you could mark it yourself?
Never had one failed by an inspector but we have moved on to the plastic fan boxes that are designed to fit on the face of and along the side of a 2x.. Very similar to the shallow pan but they have a half moon extension that extends back for added cu in.
Most likely an Arlington product. They are the most innovative.
Closer to the FB443, but not quite. Can't seem to find the image I want. Might be a different Mfg as well.
