Ultrafault
We had a situation at work where 2 of our three phase 208 volt motors started running in the wrong direction without any cause and needed to have the leads swapped to go in the forward direction. They ran in the correct direction the day before.
This is not the first time this has happened in this building, however, to different equipment; according to my co-workers. The two motors are directly across from eachother on the panel. The panel has 4 other similar pumps which continued to run in a forward direction without modification. The 4 other pumps would not have been on for some time as they supply chillers and condensors. These pumps supply hot water.
I have attached the nameplates of the pumps that have reversed without cause and apicture of the contactors. You can see that the left contactors have leads swapped to reverse the motors.
I would have said this was impossible if it had not happened. Could anyone help me understand what has happened or suggest things I should check to figure out?
Any help or ridicule would be appriciated.
Sent from my SM-N910P using Tapatalk
