al hildenbrand said:There's another variation of that setup that, as the OP states, only uses 2-conductor NM for the whole hookup.
It looks like this:
	iwire said:I want to do some Al's way just to mess with my co-workers. :grin:
Bob wouldn't mess with co-workers. Would he?stickboy1375 said:I bet they will really appreciate that....:grin:
480sparky said:Al, I took your drawing and animated it:
gndrod said:AL & 480sparky,
From the looks of the physical conductor runs, maybe Bob won't need to mess with the co-workers, I think you have succeeded in messing with my brain. If the wiring is paired to the lamp, and the switched cable is paired, I believe, a loop return violation to [300.3(B)] is considered in its own right. Regardless of the switch position, the switch connections are not cancelled pairing, thus becoming an isolated non-cancelling ungrounded conductor pair cable between the switches. Maybe I am not seeing the physical pairing arrangement....? Any help straightening me out is appreciated. rbj
:smile: Nice to know that I'm having an effect.gndrod said:I think you have succeeded in messing with my brain.
Upon reading the words in the Opening Post, I assumed that the wiring method is most likely nonmetallic. That invokes 300.3(B)(3). This allows the unbalancing of the currents, and the physical separating of current carrying conductors into different NM cables.gndrod said:If the wiring is paired to the lamp, and the switched cable is paired, I believe, a loop return violation to [300.3(B)] is considered in its own right.
Hi Al,al hildenbrand said::smile: Nice to know that I'm having an effect. Upon reading the words in the Opening Post, I assumed that the wiring method is most likely nonmetallic. That invokes 300.3(B)(3). This allows the unbalancing of the currents, and the physical separating of current carrying conductors into different NM cables.
This is not a pretty picture when one examines the EMF, but it is Code compliant.
best diagram on this ive seen. also this system is called carter system480sparky said:Here's how it works:
