And there can be intentional capacitive coupling as well. EMI filters commonly have line-to-ground and neutral-to-ground capacitors, which may put a few 10ths of milliamps on the ground conductor at 60 Hz.But it is an unavoidable aspect of the physics of the situation that there will be _some_ current on the EGC because of leakage and capacitive coupling. No insulation is perfect and even if it were there is still going to be capacitive coupling.
