mbrooke
Batteries Included
- United States
- Technician
Single phase motors need a start capacitor to get the phase shift necessary to start the motor. A 3 phase motor does not need it because the phases are already 120 degrees apart.So what do you put in 480 volt units?
Because it's still in series with motor windings, so is not subject to the full supply voltage.So how does a 440 volt cap survive in a 480 volt unit?
Does it have a capacitor wired with it? If so, what is the nameplate of the capacitor. Or conversely, does the motor nameplate specify a specific capacitor?
see post #24.I know, but I'm seeing HVAC caps rated less than the line voltage.
It fights for its' life, of course.So how does a 440 volt cap survive in a 480 volt unit?
see post #24.
What type of motor is it exactly? A PSC, CSCR, CSIR ??
It fights for its' life, of course.![]()
Ok, there's a ton of info out there about it. You have one cap, it's the "start" and "run" cap. The PSC is a dual coil with common.
What PSC motor are we talking about? Make/model please.By why is it rated less than 480?
Unless, of course, the winding and the capacitor come close to a resonant condition, in which case the voltage across both winding and capacitor can be a large multiple of the line voltage. Fortunately this does not happen when the correct capacitance is used.Because it's still in series with motor windings, so is not subject to the full supply voltage.
The descriptions there say "need cap" and on the left there's a small pic of "this item". The cap they link to seems wrong to me.Here are some examples:
There is a cap on all these motors.
It's never ideal, and the cap will always see higher than line. The MFD + inductor will dictate how the voltage builds.Unless, of course, the winding and the capacitor come close to a resonant condition, in which case the voltage across both winding and capacitor can be a large multiple of the line voltage. Fortunately this does not happen when the correct capacitance is used.
Electrolytic ???A 440 V starting cap is for single phase. It is usually an electrolytic design and NOT continuous duty.
Back to back series electrolytics in the same package are commonly referred to as AC electrolytics. I would expect life to be lower than similar construction electrolytics used in a DC biased situation.Electrolytic ???
it looks like you can either make an NP electrolytic by putting two discrete polarized electrolytics in one package (with or without a bleeder network to equalize voltages) or you can construct a three layer rather than two layer electrode wrapping to provide two electrolytic junctions in series throughout the spiral. (wrap would be anode material-cathode material-anode material, for example.)There is a special type of electrolytic capacitors for AC use, which is designed to withstand reverse polarisation. This type is called the non-polarized or NP type.
Read more http://www.capacitorguide.com/electrolytic-capacitor/
Oh well............another experience..........Back to back series electrolytics in the same package are commonly referred to as AC electrolytics. I would expect life to be lower than similar construction electrolytics used in a DC biased situation.
See added material in original post....Oh well............another experience..........
My experience is electrolytics. Large electrolytic capacitors. Typical individual banks of 2,200uF.See added material in original post....
Like DC bus capacitors in VFDs, I presume?My experience is electrolytics. Large electrolytic capacitors. Typical individual banks of 2,200uF.
