- Massachusetts
Sub metering for the purpose of selling power is likely what is not allowed.
:slaphead:
Thanks, I thought it was not allowed for the purposes of growing wheat.
Well a general statement that sub metering is illegal is just plain wrong. You can measure power all you want, what you may not be able to do is sell it.:slaphead:
In addition, the Department of Public Utilities (DPU) has ruled that the resale of electricity and gas (i.e., submetering) is not permitted in Massachusetts. Their reason for this rule is that tenants should be direct customers of the gas or electric utility and thus receive all the consumer protections enforced by DPU.
And I think the majority of places are similar, you need to be properly authorized or licensed utility to sell electric power, in most cases it is so they can collect applicable taxes and other fees and they don't want to miss a single watthour that has been billed. You can still measure where it is going for your own purposes. Even if you don't have tenants, you maybe have a plant and you just want to know what is being used by different portions of the plant.Yes, you are correct we are free purchase and install expensive metering equipment that serves no purpose.
http://www.mass.gov/eohhs/docs/dph/.../hsg-electric-gas-submetering-memo-090513.doc
Sub metering for the purpose of selling power is likely what is not allowed. If there still is a utility company meter ahead of the submetering, then the owner (where applicable) can't sell power to each tenant but can still monitor what they use for his own purposes. If utilities are included in the rent/lease and utilities increase over time then one can adjust the rent/lease fees.
Not common here, sub metering of new dwelling units not allowed.
We would have something like this in the basement or on each floor with three phase in and single phase out.
With dwellings as the "tenant's" the need for three phase in each tenant space is usually nil, you just balance the load by balancing the feeders across the three phases.Yeah this is how it's done around here but no basements lol. Ours pretty much looks exactly like this picture. The only thing is its always single phase metering and single phase unit/house panels. the only three phase is for the elevator which has its own service. The start of this thread was about a system just like this pic where you would have single phase unit panels but the main is designed for a 3phase main.
Typically if only planning to use single phase branch outputs it will cost less to use sections with single phase meter socket and single phase breakers then to use three phase units and only utilize two poles on all of them.
Yes this particular service is only supplying power to residential tenants with 120/208. So you are saying we would just use a 3phase main and then switch to single phase meter stacks?
You say to only use two poles on all of them but what about balancing the load?
As mentioned above there are meter centers that come as 3 phase, but the single phase sockets will alternate like this automatically.
You either order a stack configured how you need it or some models are field selectable.
