Typically yes.When we say 3wire circuit for lighing does it mean multi,wire circuit
Ohh! ...and there is also lighting at line-to-line voltage on a 3? system connected in delta configuration, which also uses three wires and not a MWBC. Common example of this usage is parking-lot pole lighting.
The example you refer to does not indicate how the lighting load wiring is connected to the system.in the end of the code 2008 there is an example of single phase (example d3)
