But for the inverter to run it must be connected to the grid, and if it's connected to the grid who cares if the local load is balanced or not?
The powers that be reserve the right to charge ya if things aren't up to "specs".
1. Customer generation connected to the distribution system can cause a variety of system
impacts including steady state and transient voltage changes, harmonic distortion, and
increased fault current levels. Parallel generation systems, which located individually on
higher capacity feeders may not cause very serious impacts, can, on weaker circuits, in
aggregation or in special cases (such as lightly loaded networks), significantly impact the
Company’s Distribution EPS.
2. An Impact Study and a Detailed Study in some cases is needed to identify the severity of
system impacts and the upgrades needed to avoid problems on the Company Distribution
EPS. Typically, an Impact or Detailed Study will be performed by the utility to determine if
the proposed generation on the circuit results in any relay coordination, fault current, and/or
voltage regulation problems.
3. There is a wide range of potential issues associated with the interconnection of DG facilities
to the Company Distribution EPS including, but not limited to:
• Impact on step voltage regulation equipment
• Increased fault duty on Company circuit breakers
• Interference with the operation of protection systems
• Harmonic distortion contributions
• Voltage flicker
• Ground fault overvoltages
• Islanding
• System restoration
• Power system stability
• System reinforcement
• Metering
4. It is important to scrutinize the interconnection of Customer DG facilities to the Company
Distribution EPS so that any negative impacts can be avoided and assure that the customer
generation will have only a positive or, at least, neutral impact on the EPS performance. It is
the intent of any Company study in accordance with SCDG requirements when applicable to
avoid negative power system impacts by identifying the particular type of impact that will
occur and determining the required equipment upgrades that can be installed to mitigate the
issue(s)
