GT6Steve
- Las Vegas Nevada USA
I've just seen a novel installation that has me disturbed. I'd like to hear opinions on this. It was installed as an emergency short term repair and the owner now wants to make it permanent.
It is at a remote well site. 350 HP 4160 Volt motor. They are using a generator to feed a VFD which then feeds into the 480 volt side of a transformer with the pump motor being fed from the 4160 volt side. I don't recall any disconnects other than the one to isolate the drive from the generator. They run this at a steady 48 Hz. Owner now has the opportunity to be fed from utility power and has opted for 480 volt over a 4160 volt feeder.
I question using the transformer outside of it's design parameters at first glance and then question the entire concept upon reflection. Has anyone seen such a thing and care to comment? Thanks in advance
