FREEBALL
- york pa usa
I have a 50 amp 480 volt baldor induction motor/pump fed thru a soft start controller all is brand new. The motor feeds water to a spinner system for tank washing. The motor will start and gain speed then will slow down and then gain speed and then slow down and then gain speed and then trip at 240 amps on a 100 amp breaker. The soft start does not activate. We thought it was alignment of pump and shaft causing friction but it is unknown until pump person comes out, Anybody have any familiarity to this issue.
There is another system set up beside this system same motor size on separate soft start in the same control panel, which works fine. I replaced the leads to this soft start and the same thing so I don't think it is in the soft start but in the motor or piping.
Thanx in advance
jeff
Thanx in advance
jeff
