In California inspectors know garage drywall is a prelude to occupants.............
That's silly. The rest of the country uses drywall for fire barriers.
So if it's full of household junk (very common these days), one must install receps using the 12' rule? :lol:
Office space. Define it. If it is for a commercial purpose, 6-12 does not enter the equation. Zoning codes may.Clearly " finished" is painted/ decorated and isn't like most garages that are rough mudded over drywall. Many high end houses, paint and trim to a good standard and therefore may be viewed as potentially converted into office space etc.
Sent from my SM-J700T1 using Tapatalk
If the original intended use is a residential garage, that is what it is. No further discussion, finished with sheetrock, recessed lighting and A/C, doesn't matter.
My garage is finished. Heated. Pretty nice, and occasionally I sit there in the pickup with laptop going, finishing up paperwork. Does that make it an office?
...I just don't see where the AHJ is getting it from...
I can show you a few "man cave" garages that are nicer/cleaner then some living rooms. Still a garage IMO if intended to be able to park a vehicle in there.Wow. I didn't expected that this would generate such a debate. I completely agree ad a garage is a garage. Nothing else. I just don't see where the AHJ is getting it from that 6-12 apply. I guess I will find out tomorrow.
I've had the privilege of working in some of the very nicest man caves ... the R&D garages of the Big 3.I can show you a few "man cave" garages that are nicer/cleaner ...
1 outlet per car space I am pretty certain is a 2017 NEC requirement, 1 inch conduit is likely a local requirement.Question for Sierrasparky: With regard to your comment "As of the 1st of this year You are required to install 1 outlet per car space and also 1 inch conduit to a panel with 2 pole breaker space for future car charging," is this a 2017 NEC requirement or a local one in your jurisdiction, city, state? (It does sound like a good idea given the direction automotive industry.)
Just to update
I spoke with the chief of the building department. Basically he told me that the 6-12 rule does not apply to garage. Obviously! And the AHJ that came on site must have been confused by the garage being insulated and drywalled up. He also told me that they were having issue with that particular AHJ making up rules.
Anyway, I am glad that red flag got removed
Exactly why some of us tell those that complain about an inspector that seems to be making up their own code to appeal to a supervisor or at least present code sections to that inspector that show what you think should be right, otherwise they just get used to people doing what they say (and expect them to comply with their wishes) even if they are wrong.Just to update
Just to update
Exactly!
The problem is when the AHJ or inspector refuses to listen and stands by his claim unsubstantiated. You have this case that wound up wasting the time of contractor. In other cases you have a contractor giving in to these frivolous claims in order to save time and piss off the inspector. I think most contractors are afraid of questioning a inspector as the inspector usually represents unlimited power.:rant:
Their power is limited. It becomes unlimited when contractors allow them to 'get away with it'.
Did you install those other measures I showed?
No Hard feelings if you did not.
