Question anyone know of a link to this panel type also is the panel sufficient for this calculated load does the 80% rule apply here
ok i see anyone make a panel like that
not sure if I understand how this is done any photos? TIASure, you could buy a switchboard, or you can build your own 600 amp service with wireways to separate panels. Your choice.![]()
CT cabinet ----> 600 amp disconnect----->gutter-----.3 -200 amp panels under it.
ok so this would also be the best even if I needed to put 200 amp panels in different locationsCT cabinet ----> 600 amp disconnect----->gutter-----.3 -200 amp panels under it.
How about CT cabinet ----->gutter----->3 -200 amp main breaker panels grouped in one location?
Duh! I wasn't seeing the forest for the trees.
No! Save the cost of the 600 amp disco. If your panels are grouped, use 200 amp MB panels. If the panels are distributed, use grouped 200a discos and use them to feed MLO panels.ok so this would also be the best even if I needed to put 200 amp panels in different locations
I don't think it's the trees, I think your hair is getting in the way..![]()
Ya, sometimes you're forced into using one. Cramped quarters, for instance, where you can't get them all reasonably grouped in a short distance. Apartment buildings are another, where you might only have a 600 amp service, but 12 tenant disconnects.My only concern would be the length of the service conductors inside, hence the disconnect. Without knowing the details it's hard to say.
