LarryFine
- Henrico County, VA
- Electrical Contractor
I have re-wired many 4ft fluorescent lights for bypass-type LED tubes, usually without replacing the tombstones, but sometimes with new ones. I know that some take the power at one end, some at both ends, and some accept it at either end.
For converting 8ft tubes, there are 8ft tubes, and there are "tandem" kits for converting a 2x 8ft tube light to a 4x 4ft tube light, with a plate for inserting four tombstones in the center, and obviously replacing the 1-pin tombstones with 2-pin ones.
Is there any advantage to using the tandem kits rather than the direct-fit 8ft tubes? I could see it if the job was in a place where there are already 4ft tubes in use, and they want to use the same tubes, which doesn't apply here; it's a home garage.
Is there anything else I should know? Thank you as always.
