A Service in Scotland
What makes them better? The built-in fuse?
-Hal
The fuse, the larger earth conductor (ground), the shorter live and neutral conductors, the totally insulated leads to the device.
Ummm yeah. Maybe. I see the fuse as a PITA. And all our residential receptacles are tamper proof too. I do like the insulated prongs.
What about plug/receptacles for other currents, voltages and 3 phase? We have straight prong, twist lock and anything in between.
-Hal
-Hal
Those are also “tamper proof”. The power slots have shutters that only open when the slightly longer ground pin is inserted.
-Hal
For residential it is almost always single phase 230Vac 50Hz. The plugs and sockets are 13A except for cookers. Industrial is usually 400V 3-phase 50Hz. My field was power electronics variable speed drives and mostly fairly large units at that. To that extent many were custom built.
