K8MHZ
- Electrician
This is from another forum I am a member of.
There ought a be a law...
			How old is the place you live?
When we first bought our house the electrical sockets were just the old style two hole ones, there was no return ground to any of the sockets. I solved this by running 16 gauge bare copper wire down inside the walls and connecting them to a loop of 00 gauge wire that I stapled to the undersides of the floor joists.
This was then run to the fuse box. I now have a 200 amp breaker box but the connection is the same.
I did update the sockets with the grounded three hole kind too.
If you don?t own the place you are living you might not want to invest that heavily in the wire. 00 gauge is perhaps a little on the over kill side and is quite a bit more expensive these days than it was 25 years ago when I did it and it wasn?t exactly cheap then either.
Depending on how far away the fuse box in your place is you might want to simply run a single wire to the ground plate in it.
