Nwood505
- Santa Fe NM
- Electrical contractor
Cheers to you Wayne!2020 NEC 310.3(B) does not apply to a wire so marked.
Cheers, Wayne
310.3(B) does not apply to this wire..
It is my opinion the the USE using the EC-1350 alloy is code complaint for your application.The UL Guide Information for Service Entrance Cable (TYLZ) says:
" ALUMINUM ALLOYS
Solid 12, 10 or 8 AWG conductors are Recognized under Aluminum Wire Stock, Conductor Material (DVVR2). Single-rated Type USE or USE-2 cable containing other than solid 12, 10 or 8 AWG conductors are of an EC-1350 grade aluminum alloy or a registered AA-8000 series electrical-conductor-grade aluminum alloy. In all other cables, the aluminum conductors are of a registered AA-8000 electrical-conductor-grade alloy only.
Type USE cable utilizing EC-1350 aluminum is not dual marked with any other conductor-type letters, such as RHW-2.
[/QUOTE]
Thanks for your feedback! This has been and will continue to be a big setback on my job.
I had a crew and equipment ready to go on Wednesday morning when I got shot down by a county inspector. In the meantime I’ve been in touch with all my suppliers as well as multiple inspectors that I’m friendly with. We are all confused down here in Santa Fe and up to the top brass for New Mexico!
