Pierre C Belarge
 - Westchester County, New York
This does not make sense to me.
For whatever reason I use a fused disconnect (fused meaning fuse or circuit breaker), it is the last overcurrent device between the conductor and the utilization equipment. As per the definition (which doesn't say where the OCPD has to be located - in panel, outside, inside, etc...) the conductors between the panel to the fused disconnect are feeders, and the conductors between the fused disconnect and the A/C unit are branch circuits. I believe this would have an effect on the sizing of the conductors in both locations.
"Branch circuit - the circuit conductors between the final overcurrent device protecting the circuit and the outlet(s)."
In the example we are discussing, the circuit actually starts at the fused disconnect, and the conductors supplying the fused disconnect are feeders.
This is similar to the discussion of tap conductors and feeders involving transformers. I do not agree with the CMP's decision on the proposal by Mr Dollard in regards to this, but the difference is there is more distinction here, the two definitions do not overlap as in the tap and feeder definitions.
