Grouch
- New York, NY
Hi all,
I understand this diagram of an AC coupled system. This diagram matches the diagram shown for an AC coupled system in the 2017 NEC (Article 690).
What I don't understand is the diagram below from LG, which is also an AC coupled system. During a power outage, the PV array and batteries (the battery is the largest box in the diagram, in the middle, with its inverter to the left) can both still be providing power to the critical loads panel, via their respective inverters. However, in this LG diagram, won't the PV array still be providing power to the main / normal panel, while it's providing power to the critical loads panel? the main panel is in series with the critical loads panel; the power from the PV array has to go through the normal panel to reach the critical loads panel. The auto-tx switch box is a transfer switch, but I don't see how this is supposed to work.
