Carultch
- Massachusetts
It would be called something else entirely, if it could break off a connection to the utility. All a meter can do, is measure what power, energy, and characteristics of the voltage and current waveforms, pass through a point in the circuit. RS485 just refers to the communication technology.Unless that power meter with RS 485 can break off utility.
Even if it did use the meter as feedback to prevent export during an outage, it still would not comply with anti-islanding requirements. The service drop needs to remain completely de-energized, as opposed to just having zero current.
Agreed. That's probably the intent. The fact that there is existing solar would most likely be irrelevant to the functionality of the battery backup system.It also occurred to me this LG diagram may be intended to add battery backup to existing solar equipment that shuts down the PV during utility outages.
The battery backup system would have a limited runtime on only what the batteries could provide. In concept, it could also perform load profile management tasks such as time-of-use energy arbitrage, demand mitigation, and zero-export recapture. However, these applications a battery are mutually exclusive to the application of backup power. Because you could have a power outage at a time when your batteries are intentionally discharged for the cycle of load profile management, unless the control system designates a portion of the battery capacity to each task.
